Hi I have a 3 gene with Ohlins TTX shock (100N spring) and Ohlins front piston kit (spring 10). I have a problem in the corners, I can not get into the slope and the bike is understeer when I want to cut bend. store front in a Triple is standard and the rear shock absorber + 2mm in length. Please what settings you use for the racetrack. Thank you for the information.
front
compression 13
rebound 16
rear
compression 12
rebound 12
front
compression 13
rebound 16
rear
compression 12
rebound 12
