I built a 2010 engine, +3mm bore +4mm stroker crank JE stroker pistons 2014 velocity ported head 2014 throttle bodies & round venturas back cut * polished transmission with ceramic bearings, so to be gentle i fitted the stock Gen4 cams on stock timing with a standard thickness 79mm head gasket put her on a dyno where a stock 2017 GSXR 1000 put down 190 RHP she put down 209 DIN power with 96flb torque. I go away inspect the bores etc decide its all good & fit Big Kent cams and dial emm in 112 112 go back dyno expecting bike to come alive and after bout 40 45 mins dyno time re mapping her pish starts spewing out expansion tank i got bubbles so most likely head gasket, well im gonna tear her down (American Slang:smile2
tomorrrow have a look :dontknow:
