1 - 3 of 3 Posts
I'm stuck with my gen1 hid installation. Got a 55w 6000k kit from ebay. Clutch side lights up fine but when i try to light up the brake side it just flashes and goes off. If i unplug the clutch side harness the brake side lights up normally. They both ligbt up but i cant figure out how to make them light up both at the same time whsn needed. Just to let you know i have already swapped the 10A fuse to 15A. The bulbs and ballasts are good on both sides.
Sounds like you don’t have enough amperage to power both ballast. Most HID on eBay are DC ballast and its very sensitive to load change. You might have to use a relay to power 1 of the ballast. BTW putting bigger fuses is not going to help you increase amperage.
1 - 3 of 3 Posts
