Gen 5 Torque Specs?
8720 Views 5 Replies 4 Participants Last post by  Victors
Drain plug -
Front Axle -
Front Fork pinch bolts -
Front Brake Caliper bolts -
Rear Axle nut -
Front Sprocket Nut -
Rear Sprocket Nut -
Thx
1 - 6 of 6 Posts
Read the manual.
Welcome.
  • Like
Reactions: 1
*snipped*
Get one.. or download it.
Wow, just wow
yes, download manual but for g4 front and read axle are both 100 pounds. Snug up the rest of your list. I do NOT use the cotter pin in rear axle and suspect g5 still has it. I install axle from the left as easier for me due to past bikes. For front pinch bolts be absolutely careful to get the allen head deep inside as those are soft and strip if torqued too shallow.
yes, download manual but for g4 front and read axle are both 100 pounds. Snug up the rest of your list. I do NOT use the cotter pin in rear axle and suspect g5 still has it. I install axle from the left as easier for me due to past bikes. For front pinch bolts be absolutely careful to get the allen hean deep inside as those are soft and strip if torqued too shallow.
Actually it's 94 ft lbs on the g4
  • Like
Reactions: 1
1 - 6 of 6 Posts
