Well done. Thats quick. What mods have you done to it and did you do it with electronics deactivated?
Thx , Graves exhaust , Woolich flash, Sprint PO8 airfilter, 520 chain Conversion 16/40
Everything off
that is very fast for stock wheel base and stock ride height, doesn't look like you had the front strapped on the action shots. The best i could get my 4th gen was 10.3 stock wheelbase and hieght, ecu flash/slip on and gearing. Couldn't keep the front end down for the life of me curious if you were running with tc on and if so what setting worked best for you? went through a clutch in one day too trying to get a good launch.
The bike was strapped when i ran 9.52, but i went 9.7 with no strap. No tc , everything off
I also went through my stock clutch after like 6 runs , but i changed the Gearing and went with cycleconcepts Drag pak clutch (backdated gen 1 with a judder plate) works way better
Did you use launch control? If not, why not? Did you try it?
I did not, i have tried it and i dont like it, always went slower
