If you are replacing the front brake pads on a gen 5 and push the pistons back into the calipers can this cause ABS issues? If so how do you electronically bleed the ABS pump?
My 2012 BMW s1000rr would have issues if you did this and did not electronically run the ABS bleed circuit.....even the dealer did not know this!
