Can anyone who has had their 2016+ CCT (Cam Chain Tensioner) replaced via the service bulletin tell me what color the replacement CCT is?
So what your saying is, the replacement tensioner is an automatic, not a manual? I just want to know if my dealer used the part that kawasaki sent them or just grabbed some used one and slapped it on my bike. My tensioner looks kinda beat up, in addition to being black, where the oem was silver.Um, yeah. So, the cam chain tensioner isn't drastically different. From my understanding, the difference is internal with the spring force. There's no way to tell externally if it's the later version. The center bolt isn't a bolt at all. It's a cap.
Yeah, i've replaced an automatic CCT before. Dealer told me the new tensioner (new part # not the old one), is actually the same tensioner from the older ZX10 models, what year I don't know. It honestly looks like something off a 2005. The black is all marred and pitted, hardly looks new at all.There is no such thing as a manual tensioner - from Kawasaki that is. All manual tensioners are aftermarket only. No, both of them are non-return, automatic tensioners. You'd have to remove the CCT to see if it's been replaced. And that will require you to reset it before putting it back in, and hope that you install it correctly so you can get the tension correct without over-stressing the cams and chain or allowing too much slack in it.
Actually yes there is such a thing, all the KAWASAKI Race Kit tensioners are manual. Gotcha on that 1 Skydork. However, I digress, you are talking about what comes stock on the bike and yes they are all autos lol.
I have the Kawasaki OEM "KIT" manual one on my bike. Bought it from Greenman43 from OZ several years ago.
Skydork, is there any benefit to a manual tensioner like the one from APE, vs the replacement one provided by the dealer?Awww, man. I knew someone would go Stock or Race Kit on me. :badteeth: I need to read better and phrase my responses better. You have my rep for catching me on that one. Nice! :thumbsup:
Somewhat disagree, race teams use manuals because the auto ones "can" back off slightly at very high max revs when backing off the throttle causing severe engine damage where manual ones will not. That really is the one advantage, under racing conditions.Functionally, no. The only real benefit is being able to quickly and easily adjust the tension when the head has been off or swapping cams often. For racing scenarios where engine disassembly happens a lot, a manual tensioner has its advantages. On a street bike, a manual tensioner is overkill and most people don't properly adjust it anyway. They just keep torquing it until it's "tight" and that can overstress the chain, chain guides, cams, and crank.
Gear driven cams from the crankshaft a la Honda VFR , pretty much maintenance free, but slightly noisier :smile2:You would think by now the Japs would be able to make a decent cam chain tensioner and regulator rectifiers, but it just seems year after year after year some jap manufacterer has some issues with these 2 items. It boggles the mind really. :dontknow:
