Could work but valve timing is different, might not do any good. Someone will try it, most likely.Just thought Id share an observation I noticed, the Gen 5 velocity stacks are different to the Gen 4. Would be an interesting experiment to put Gen 5's on a Gen 4 as they use the same mounting size :grin2:
thoughts?
haha put 2016 cam's in tooCould work but valve timing is different, might not do any good. Someone will try it, most likely.
I believe dang near every part is different on the '16.
