1 - 9 of 9 Posts
Speed Freak
No one is running TRE's on the gen 4's for the most part because your bike will still be limited in every gear.
Search "Guhl Motors" ecu flash and you will find all the info you need. :thumbsup:
reflash is a must on a US Gen IV, a powercommander, any full exhaust will not get you the gains a reflashed ECU can to take off the top end restriction above 11K RPM.......
Guhl Motors is well worth it...should be the first power upgrade...and he has awesome maps to go with your slip on/full exhaust system, get rid of exhaust servo FI light, etc....
See ... that's the frustration of info gained from the internet.
I had this very discussion here a few weeks back, and was assured that the X-tre (or similar) is not needed on the Gen 4, that it doesn't work - I forget the reason.
Anyhow, a few weeks ago I spoke to a race mechanic, he sets up lots of local race bikes inc suspension, dyno etc .... and I asked him this very question. His reply? The race teams certainly use a Timing Retard Eliminator on the Gen 4.
So now what? :dontknow:
Gen2 Ripper
How can they run a Tre with a KIT ecu? Doesn't make a sense.
I have no idea how it works etc, I don't know what a KIT ecu is, suffice to say that IF this person fits them and he says that the race teams use them, they do - period. So let's start with the assumption that they do work and they are beneficial, and go from there. It's an assumption, it's always possible that this info is incorrect but I doubt that very much.
Usually a Bazzaz is also fitted, does that help?
1 - 9 of 9 Posts
