1 - 5 of 5 Posts
Can someone tell me of after market shims for my zx10 2012. Also the correct diameter. Thanks gum
Valve shims? Shock shims? What kind of shims are you looking for? A little bit more information would help here. :dontknow:
hot cams offers direct replacement shims at a fraction of the cost of oem. correct shim size is 7.48. u can choose selection on ebay. no problems, sized correctly. kit price less than a buck apiece. can order exact size needed for hot cams direct. my closest dealer priced them at $13 a piece oem.
Sorry valve shims. Will order today. The dealers here slug 8bucks change over but have now stopped this and charge 25 bucks a shim. That's over 20 USD. Then they complain that everyone buys from the US. Go figure. Thanks gum
Have not done the 10 yet, but I have used the Pro X shims from Rocky Mountain ATV on my other bikes.
Here's a link to the 7.48mm if that's the right size.
$1.99 each and available in "half sizes" too.
https://www.rockymountainatvmc.com/p/922/26634/Pro-X-Valve-Shim?term=shim
The prob with a kit is you end up with a bunch of sizes
you will never use.
Didn't realize Hotcam sells single shims, last time (long time ago) they
only offered a "refill" for the kit. Like 10? in a bag.
1 - 5 of 5 Posts
