1 - 7 of 7 Posts
Installed a PC w/autotune and had the cylinder dropping issue, plus irratic idle. Downloaded firmware and it appears to have fixed the cylinder dropping issue but the idle is still irratic. What I mean by irratic is that it will jump from 1k-1.1k to 1.2k-1.4k and then drop back down every few seconds or so.
I also did the block off plates and installed bazazz quick shifter.
Anyone else possibly experience this? :dontknow:
Gen2 Ripper
So it's jumping 11K RPM!!? Something isn't right.
Is this only when in Neutral or with the clutch engaged but in gear?
I have only noticed it at idle in neutral I will have to see if it does it when in gear with clutch disengaged. It's fluctuating 1100 - 1200 rpm not 11K-12K as originall posted. Just surges every few seconds or so.
If you eliminated the cat,,, it will lope,, normal,,,
Understood, but it was not this exagerated until I installed PC, Autotune, and Bazazz QS.
Track day this weekend so i'll see how she performs and then I'll remove the PC and see if idle comes back to normal.
1 - 7 of 7 Posts
