well, not sure.. I haven't messed with it, maybe it's just set too low? I've never redlined it or anything but does seem like it's flashing too early, guess I should read my manualThat's kind of what it's designed to do. To get your attention and shift. Hence the reason it's called a "shift indication". Why are you running the engine up that high and allowing it to flash so much? What is it set to?
i wouldn't have noticed there was one except for the multi colored bright flashing lightsWe have a tachometer???
Damn dude! You don't screw around, do you? ??? You're at 13,500 and thinking the shift light shouldn't be on yet? I'm not even sure I've been to 13,500. If I have I was ready to shift or hit the brakes anyway. I just shift when it begins to flash. The gauge cluster was one of the things I liked most about Kawasaki. Don't even have to look and you can get an idea of the rpm range where the bike is running. I find it useful because I often ride longer distances with ear buds playing music so I can't hardly hear the bike.Okay, so I checked it and it was set at 13,500 and fast flashing , I changed it to slow flashing .. maybe I was running it harder than I thought, it's the first liter bike I've owned that had to tach so high before it started pulling hard
