Little back story on the bike.
2013 10r... Bought it from an idiot last fall. Didnt get to ride it cept the test ride until this spring. Over the winter I changed the clipons and did all the maintenance the previous owner didnt do. Got the bike out recently and the front end would rattle/clunk on bumps and was very bad when braking on other than a smooth surface. Immediately turned around and realized i had the clipons a tad high which kept the triple from completely seating. Did some adjustments and reset the upper triple and torqued the nut.
Long story short, the issue is still there. Double and triple checked to make sure the upper triple is correct and it is. A google search suggests its the steering head bearing, forks bottoming out internally.. etc
Ive checked for a loose bearing and seems fine... any ideas?
Thanks guys
Thanks guys
