1 - 7 of 7 Posts
Squid wannabe
They are larger than the gen 1. Would require 5mm spacers for the calipers.
Someone might be selling some T-Drive 320mm discs which he had for his gen4, but he sold it and got a gen5 so he won't be able to use those Brembo's.
I already have 320mm HPK Brembo's, so diameter wise they will fit. Just need to know really if they will fit on the rim itself.
I'm fairly certain that they will not fit. The Gen 1 disc carrier is flat, while I believe the Gen 4 is offset. From looking at a Brembo box, it appears the carrier, Gen 4, has a 15mm offset.
I realize this is an older post, and you may have the answer already.
Both discs are flat, so no offset, it's the bolt pattern I need to know if they match up is all
T-Drive Front Floating Rotor Kit (320mm) - 208A98522
  • Kawasaki ZX10R 2004-2015
  • Kawasaki ZX14 (ABS) (ZZR1400) 2008-2015
  • Kawasaki ZX14 (ZZR1400) 2006-2015
  • Kawasaki ZX6R 2005-2016
The following bikes have 300mm rotors stock, 320mm rotors can be used but additional spacers / longer bolts will be required.
  • Kawasaki ZX6R 2005-2010
  • Kawasaki ZX10R 2004-2010
1 - 7 of 7 Posts
