It's time to do my clutch in my gen 5 as it finally bit the bullet on the strip, everything I've seen is showing that gen 4 is the same stack height as the Gen 5, I have an extra Cycle Concepts Drag Pak with springs for my 2011, will this work in my gen 5? I've found certain things from my '11 will bolt right up such as my strap and lowering link, etc so am I correct that I can drop this in?
Also some searching brought up in another thread that someone had a post about everything that will fit between gen 4 and 5, but I can't find it in the search?
Thanks in advance.
Thanks in advance.
