Bank Holiday out of the way, I was able to speak to the original owner and builder.
The bike went from 2000 mile mint bike in 2013 to a £60k total full SBK build, full Öhlins front and rear, SBK swingarm etc. It was returned to Super Stock spec then raced twice, 12 track days and stored when Gen 5 bikes came out.
Apart from an oil change, it’s good to go.
here’s the engine spec:
Engine – Full MSS spec – flowed + ported head , re profiled cams , lightened + balanced crank , super finished casings , 8 new exhaust valves fitted last rebuild , NGK R 10 SD plugs, [ £ 400.00 a set !! ] shimmed box with 3 new gears from last rebuild . 200 bhp without baffle / 185 with
Rest of build:
Electrics – Motec CDL 3 dash with bespoke Scott Smart harness connecting into Kit loom / Kit ecu . Telemetry available on harness for front + rear suspension / oil pressure / brake pressure / water temp / lap timing – splits , rain light + all the usual tech that the dash has available to download / Avio switch gear / rain light / flash
K tec DDS pro shock
Leo Vince full Ti sbk system with baffle
Samco hoses + clips
DBS adjustable rear sets
Hel Braided lines
Brembo front master cylinder 19 X 20
Ohlins [ std ] front mounted steering damper
Clip ons + grips - new
MSS steering stops – new
MSS top hat tank mounts
Carbonin air intake / dash surround
Evo tec protective dash case
R + G radiator guard
Carbon frame protectors [ easily removable to check frame ]
Full set of GB racing covers / ears / sharks fin / new bobbins
Front brake lever guard – new
Dynajet quick shifter – RACE SHIFT – can offer road shift module if preferred .
QA throttle / new Venhill cables
K + N filter
Harris Quick release fuel cap
Captive wheel spacers - new
520 Renthal chain / front / rear sprockets
Lightweight battery
King Carbon sbk bodywork - vgc in black white + silver
Wheels fitted with new / unused Pirelli wets
