Yes that does work.Rather than follow the service manuals confusing procedure. My take is to just turn crank clockwise until whatever set of valves your checking has its lobes in upward pos. Then use the feeler guages. Would this work?
Thx, if they are not within limits, I will probably leave it taken apart and send it to the shop. Have no idea how or where you apply the shims. Unless you know of a resource where I can understand. Thx again for the reply sir.Yes that does work.
I appreciate the response, just doing some research. Noticed when I was changing the oil that the fairings were put together wrong. Bought the bike from them and after draining the oil I noticed it pretty clean. So they must have changed it. If they can't figure out or don't care how the lower fairings are put together....I don't want them fucking with the valves..still got 1,500mi to go to get to 15k. ThxSearch on YouTube. There are plenty of video guides on how to do a valve clearance job. It doesn't have to be a video about your specific bike model and year. Just watch one to learn what to look for and then do it according to the directions written in your manual and it should make more sense.
