1 - 2 of 2 Posts
Hi, I ohlins TTX rear schock and front fork valve rebuild by Ohlins. I find some set-up data from racetrack rider with the same. My weight is 90 kg (198 lb) with gear. Front spring 10. Rear spring 90 Nm. First time ride with 100 Nm spring (recommended for racetrack for ma weight by my dealer), but too hard. Now is 90 Nm. Now it´s comparatively good, but it's not ideal. You can write specific settings which are used? Thanks.
Discussion Starter #2
Front and rear SAG - 27mm
rear compression 12 (stock)
rear rebound 12 (stock)
front compression 5
front rebound 12
1 - 2 of 2 Posts
