1 - 5 of 5 Posts
So I just set the sag on my bike. I had replaced the oem spring with a 10.7kg spring from race tech. I have the sag set to 35mm. The bike rides and handles so much better. Now I stand flat footed though. I know having the ass of the bike higher up again will help with turn-in. I was curious if anyone has tried the "jack up kits" before. Kinda like a lowering link but brings the bike up.
http://www.lustracing.co.uk/suspension/kawasaki-jack-up-kits.html
rear ride height affects squat on acceleration a d having the rear high steepens the rake angle and trail numbers. you can just stack washers on the top of the shock mount to frame to add height. ive never seen a jack up kit used so i cant say anything on that
Did you get the 1/2 spacer from Racetech that goes with the shock?
Take a stock shock shim (AKA a thick alloy washer that is between the shock mount and frame on lots of zx6rs 06 and up). Just put it between the shock mount and frame. Just one will jack up your bikes rear end and help it turn a lot but will also make the zx10 shake its head even more.
1 - 5 of 5 Posts
