1 - 2 of 2 Posts
Name This Gen 2 Part
Anyone know what this chewed piece of rubber is? See below... It was hanging on the water pump shaft when I pulled it out of the motor. I dont see anything like it on the part diagrams. Is there a rubber seal that sits behind the impeller?
Discussion Starter #2
I pulled the pump apart to have a look inside. I see no place for that piece of rubber. There is a seal, a rubber oring and a spring behind the impeller. Everything looks right from the pics Ive seen online.
I pulled the pump off because of a leak. Coolant was leaking near the top of the pump and running down the side of it. Ended up being the top hose that goes from thermostat to pump leaking at the pump fitting. So Im going to replace the hoses & give it a shot.
Anyone have ideas on that piece of rubber? Maybe something from in the case?
1 - 2 of 2 Posts
