1 - 2 of 2 Posts
Hey fam bam I hava a 2006 ZX-10 im trying to remove the valve cover gasket do you guys have any pointers of how to do it. Would I need to tilt the motor to get access to the cover Thanks guys and gals
No you won't have to tilt the motor or anything. You will need a kinda long bungee cord to hold the throttle bodies instead of disconnecting the throttle lines. Thats the only tip I would tell you. The rest is pretty straight foward. Good luck.
1 - 2 of 2 Posts
