1 - 14 of 14 Posts
Ok ok ok,elbow its been beat to death on here, but I just want to know what works to help elim this. Gen 1 clutch, judder spring, or what? I wanna offer today so advise asap is preffered...Clutch is fine just sucks to launch!
alot of gen2-gen3 guys are converting over to the gen1 clutch pak bc its much better... you wanna get fibers, steels and judder spring for a gen1... that should take care of the bucking, clutch chatter your hearing.
So just call concept and get the whole "pak"? Are ths steels and friction plates that much different?
I have the same problem what is the judder spring
judder spring is the 2 steel plates thats together... it helps eliminate the noise you hear when launching.
yep tell em you want a clutch pak for a gen1... once you go gen1 you want wanna go back :wink:
judder spring is 2 steels that basially are sprung together to put pressure against the entire pack to ensure everything is together.
I never had this issue after welding the basket to dissable slipper, Brocks also makes a washer/spacer that does the same thing. I still use 3rd stock clutches and judder spring
1 - 14 of 14 Posts
