1 - 6 of 6 Posts
Hi guys just wondering if anybody has actually had a negetive response from fitting a tre and removed it and what side effects did the bike have on theres on any model? Thanks
What's a TRE? :dontknow:
Cheers mate. I have a slight stutter/missfire at off/on throttle. Im just wondeting if a tre can cause effects like this. It a nikko g pack I have
Go do your research but I have a home made TRE and a switch if anything the TRE helps the on-off throttle it fools the bike it's on neutral and no fuel is cut like the other gears....might want to check your setup again or it's something else.
Bloo
Ive removed item and going to check it out next time im out. If there still I think im gonna get new plugs again
1 - 6 of 6 Posts
