1 - 3 of 3 Posts
I got a set of used ohlins forks for my gen 1 zx10r. Before I installed them I took them apart and changed the oil with new ohlins fork oil and changed the springs for my weight. After I installed the forks and started riding the bike there seems to be what feels like a vibration coming from the fork legs at certain rpm ranges. Its almost like the fork spring is vibrating against the fork outer tube. Has anyone experienced this?
Did you
I don"t know if it's matter but did you put (probably) the right tube with the right fork, mean not the left with the right ?
There's something loose some where
Ya they are on correctly. The damping rod is tight every thing whent back together fine. I guess I will just have to take them apart again.
1 - 3 of 3 Posts
