1 - 3 of 3 Posts
Can anyone post a pic or describe where can I find the engine case marking. Are there marking on the top and bottom cases ?
I'm running into clearance issues on my re build. The bike had a 4mil crank in it and i replaced the crank with a stock crank from another bike. Went to mic the main journals and we are tight on clearance.
thanks in advance
Gen2 Ripper
some one correct me if i am wrong, but you need to buy top and bottom cases as a set, as they are machined together. there is the no hole, one hole, and two hole designation for the cases and there is also a mark on the crank, certain crankshaft work with certain hole designation crankcases.
here is my thread on the same issue:
http://www.zx-10r.net/forum/showthread.php?t=107845
Correct. Must use cases from a matching set. Can not mix case halves. Uncertain if that is your problem or not.
1 - 3 of 3 Posts
