my 04 zx10r wont go over 8000 rpm no matter what gear its in...SOMEtimes it will go to redline in neutral. it has a two brothers racing exhaust and a power commander 3. heres what i've done...
-full diagnostic (18 errors on the secondary butterflies) so i removed them...no change so its not them. and no other failures except cam shaft position sensor 3 times. no biggie. (all other values are good)
-removed exhaust butterfly (unkooked cables under seat so its always open)
-disabled kickstand switch
-removed little roley thing from tip over sensor.
-ran with power commander unhooked, ran "zero map", two brothers map, and currently running 'butterflies removed' map...no changes in any circumstance.
-local kawi shop tested fuel pressure (at idle...they didnt drive and test at the same time..probably should be my next step (i know)... they said fuel pressure is excelent.
-ran octane booster and injector cleaner (i run 91).
if i let off the throttle a bit it climbs up to 9000..sometimes 10000.
any help from anyone? please and thank you.
