1 - 20 of 21 Posts
I am trying to find gears for my bike what would be a good set up for the 1/4 mile.I weight 270 and it fells like i need more top end. I am getting 1.6 to 1.8 60 FT.I am starched about 7 inchs and a slip on.Thank you
i am down 2 f an up 2r in rear 60fts good and 146 1/4 mile im 200lbs when it was just 1down f and 2 up rear 60 ft wasnt rear good with your weight -2 would realy help you
What year is your bike? the 04 and 05's shock is 17t 39t.
Im running 16t 42t now got my best 60 yesterday 1.53
not sure but i think the 06 and 07 are 17t 40t. Hope it help some im 62'' 1\2
best run 9.62 @ 141
Discussion Starter #8
i am kinda on a budget so i am going to just do the front or back. Which one is better to do 1st.
Speed Freak
front it a lot cheaper and will give it a good jump in acceleration. I say go down to a 16 tooth up front and see how it feels...possibly a 15 tooth up front??? but I don't know about that, seems like the chain would have to have such a tight area to bend in ya know???
XSPOWER what gear are you going through the trap? Im thinking about tring that gearing 15t 42t = 2.8 but for my bike it's like 16t 45t = 2.81 im about 190 suited
I ment -1 front and +1 out back
Man i like tring stuff but with -1 +1 I liked it alot but the next week I changed it to -1t 42t only because its geting cold in ohio and im running out of track time. that 40t rear was alot better then that 39 alot better and it was easy to ride. I got me a steel gear it was about 30bucks.
I was thinking about tring that but everbody say it kill's you chain how yo chain look? Is your bike long?
that 15t 42t =2.8 I might go 16t 45t =2.81 But i wont need more chain with that 15t. Tone
how would -1 front and +1 back do
I was going to suggest that to start. Then go from there. Get rid of that 15 tooth front though and go with a 16. The 15 is too small I know that a bunch of guys run them and that they work for some of them but there are better options out there. Plus our chains don't like to bend that much, you could end up skipping teeth. As for going up one tooth in the rear it really won't make that much difference but like I said it's a good starting point. I"m -1+3 I beleive right now. I weigh less than you but I pull mid 1.40 60's to low 1.4 60's and run pretty good with that set up. Also dial in your suspension for your weight to help you get a better launch. It makes a difference. Also try to get off of the clutch faster, once you get used to the new set up and the difference in the power band. Take your time and you'll suprise your self in no time. Good luck.:eek:ccasion1
1 - 20 of 21 Posts
