1 - 6 of 6 Posts
Thanks guys. Should have clarified this. My 10r is fine. This is a problem Im having with my 04 636.I get more and better replies going through the 10r net. What did you mean by jump/ground the FI lead and read the code. You lost me.
Late Apex
thats how you get the FI code ... just do a google search or
to check the code remove the seat and there is a plug by your ecu with a cap on it .. unplug the cap and run a jump a wire from one terminal to the next inside the plug by using a speaker wire or anything really . paperclip works too... turn the bike on, count the flashes and refer back to the site with the count and we can chime in to help.
The error codes are listed n the service manual ..
1 - 6 of 6 Posts
