I gotta admit that I'm a little embarrassed asking this question as I've made this adjustment a score of times before on other bikes, but on my 1st Gen ZX-10R, it's not cooperating. I'm stumped.
I need to adjust my gear shift pedal lever down as I can barely reach it. I totally loosened the clamp that secures the linkage...
to the main rod that runs through the motor, but I can't get it to slide out & off so I can rotate it on the splines to adjust the pedal lever down. It is loose & it will slide out, but it stops & just won't come all the way off. There are no visible burrs or obstructions that would cause it's travel to cease, but it just stops.
Is there a step that I'm missing on the 1st Gen ZX-10R.?! :|
