1 - 20 of 22 Posts
Hi
Does anyone use a Gear indicator to show which gear they are in. I have recently designed one myself at a fraction of the cost of the Datatool one.
I personly find it very useful as I sometimes forget which gear i am in on my zx10. This being my first big bike.
Adam
Speed Freak
theres a buncha people on here that have them and a few others have made their own, you should post up pics of yours to show.
Mine cost me about £5 to make myself. I could probably make it even cheaper if i wanted too.
I got a Gipro gear indicator...I was the same way wasnt sure what gear I was in, but now that Im used to the bike I dont really use it as much, but still nice to have.
I'd love to know how!
nice i never mess with surface mount stuff as it is so hard to solder. what did you use to solder them without overheating the IC's. There rated normaly at 300* for less than 5-10 sec. and a normal soldering iron runs in the 850 range.
Discussion Starter #12
I just used a soldering iron (Weller) it has adjustable heat control so I can set it to around 300 degrees.
Custom Powder Coater
Not bad looking Adam..
What type of solder you use? Surface mounts are a bitch we do them at work also have a wave machine whcih i prefer..
Discussion Starter #14
I just used lead free solder and soldered everything manually. It's ok if i'm only making of them.
Nice
I wish I had the know how to make one, because I would like to have one just don't want to spend the $$ on it. I wouldn't mind learning how to either.
Speed Freak
ditto... I really am interested i the gear indicator DS from healtech, plugs into the diagnostic port of the bike...
So when is the "how-to" going up on this gear indicator? I don't mind surface mount, did the ones on my speedo with no problem, just a little tedious.
Speed Freak
yeah would be nice to find a good how to....
That or let us know how much it would take for you to make some for some forum members :thumbsup:
1 - 20 of 22 Posts
