1 - 8 of 8 Posts
With the gears being so close together, I would really like a gear indicator on this bike. Can anyone recommend one?
I had one fitted when I got my alarm, v v handy especially to stop the search for 7th and to make sure your in the right gear for those corners, lets you concentrate on other stuff instead of wondering what gear your in. Acumen are the same as Datatool, the same bloke designed both but switched companies.
yep, although there might be a plug in version by now. He did have trouble getting a good feed from the speedo as it goes via the ECU so think he had to splice into the pickup at the sprocket. Works fine though.
i had a datatool Digi gear indicator fitted a couple of weeks ago, as i'm always hunting for 7th.
its also very useful at the track for ensuring i'm in the correct gear for each corner etc..
it cost £90 GBP ($160 US) fitted.
Note '0' denotes neutral
sorry the pics a bit ropey :roll:
1 - 8 of 8 Posts
