1 - 20 of 139 Posts
RidersDiscount.com now carries GB Racing components! Designed and manufactured in the UK, GB Racing has become recognized for employing excellent engineering capabilities to create bolt-on motorcycle crash protection products. The FIM-approved components are manufactured using injection molded engineering-grade long glass filled nylon 6.6 (LGFN 60%). This material offers excellent impact resistance when compared to other machined plastics. In fact, injection molded LGFN 60% has 4.6x greater tensile strength and 6x greater impact strength when compared to Delrin motorcycle parts! All secondary case covers come with A2 stainless steel socket cap bolts and Class 12.8 steel hex head bolts. The 12.8 hex head bolts are bright zinc plated and then de-embrittled to reduce the likelihood of bolt sheering. A2 stainless steel socket cap bolts were chosen for use in GB Racing frame sliders for the material’s excellent elastic modulus, meaning they are more likely to bend instead of just breaking in a crash. This choice of hardware ensures the protective equipment will stay in place when they are called into duty.
As you can see, GB Racing is an engineering company that’s passionate about motorcycle parts! These physical properties lend themselves well to motorcycle crash protection and their implication in GB Racing products has brought the company much notoriety in European racing leagues. Every GB racing component starts life on a computer using 3D CAD/CAM modeling to render close-fitting parts that require few, if any modifications to your motorcycle to install.
GB Racing Protection bundles includes select components for your motorcycle to help reduce the likelihood of damage in a crash. All required hardware is included with every piece as well as clear installation instructions.
We have kits for all 2008-2014 Kawasaki ZX10R models.
GB Racing parts are not yet available on our website, to order yours, call MIKE at 866.931.6644 ext 804 or send an email to FORUM at RIDERSDISCOUNT dot COM with ZX10R GBRACING BUNDLE KIT in the subject line and please be sure to include the model and year of your motorcycle for accurate availability.
A typical GB Racing Protection Bundle includes: clutch cover, stator cover, ignition timing cover and shark guard, though the exact composition varies from model-to-model.
GB Racing ignition timing cover.
Swingarm stand spools are made with a combination of glass-filled nylon and CNC-machined bases.
Stator cover from GB Racing.
Notice the metal collets located at each mounting point. These are found on every GB Racing secondary case cover to ensure bolt stability and enhance crash resistance of the engine cover.
GB Racing secondary clutch cover also enhances protection of the clutch actuator arm on many motorcycles making it less likely to suffer a damaging blow in a crash.
A motorcycle shark guard is designed to prevent the rider from losing his or toes between the chain and the rear sprocket. It’s cheap insurance.
Some motorcycles come with bungs for attaching a shark guard, just use the included hardware to bolt it on to your bike. For bikes that do not include this component, a mounting bracket is included though you will have to drill and tap your swingarm to install this safety device.
GB Racing secondary engine covers are FIM-approved and can be found on some of the fastest motorcycle in the world. Shown here is the GB Racing-equipped RidersDiscount.com-sponsored Moto2 racer as ridden by wildcard Jason DiSalvo at the 2010 Indianapolis MotoGP round. If it’s good enough for Moto2, it’s good enough for anyone!
GB Racing is rather new, so they're probably working backwards from the latest models. If/when they do produce stuff for the 1st generation ZX10R, we'll let you know right here!
:cool:
Gen2 Ripper
I like the shark guard for the chain. Though, I need one for a 2nd Gen:badteeth:.
Price Please on Gen 4.
I wish they had red ones, they dont do they? lol
1 - 20 of 139 Posts
