1 - 2 of 2 Posts
Meh. Fit and finish is marginal. I needed a washer under each bolt to keep them from resting on the cases. Definitely a track item. Installed as delivered they will tear up the finish on the cases. Two defects: One "leg" on the clutch cover is loose as the spacer extends out the inside creating a slight gap and some movement. Probably from an incomplete mold fill leaving the plastic leg a bit short. Need to file it down and add another washer. The pulse cover had a rough edge on it from an incomplete mold fill. Maybe they do a good job at protecting, but quality control is piss poor.
Discussion Starter · #2 ·
Update: On the plus side, they don't dissolve when you clean the nasty white logo paint off with brake cleaner.
1 - 2 of 2 Posts
