1 - 9 of 9 Posts
Galfer GP Brake Line Kits are designed not only to improve the stopping power of your motorcycle when compared to OEM brake lines, but also afford the user extra up/down adjustability of the brake master cylinder. With only one line coming off the master cylinder, a shorter banjo bolt is employed, allowing the rider to run the brake lever as steep as he wants. This single line running off the master cylinder then goes to a T junction, which is placed just below the lower triple clamp from which point the brake lines go around the outside of the forks to each brake caliper (ala GP bikes). All fluid is contained within polytetrafluoroethylene (Teflon) coated stainless steel braided brake lines that don’t expand under pressure, improving feel and control at the lever.
All required hardware is included with these kits. In the box you will also find a clear set of instructions and pre-labeled hoses so you can tell what goes where.
Available for 2004 and up ZX10R
Call TJ at 866.931.6644 ext 817 to get a set of these stainless steel brake lines sent to you today. You can also email us, send those to FORUM at RIDERSDISCOUNT dot COM with GALFER GP in the subject line along with the model and year of the motorcycle you’re riding for accurate availability.
Out of the box, line ends are clearly labeled for easy installation.
All banjo fittings are anodized blue and the stainless steel hoses are clear-coated for added durability.
All banjo bolts are anodized red.
Could you PM me a price shipped to 97219. These would be for an '04 ZX10R with ZX14 Nissin Calipers and radial master cylinder.
Thanks,
D
1 - 9 of 9 Posts
