1 - 2 of 2 Posts
Galfer Wave rotors are known throughout the world for the exceptional stopping power. And of course, they applied their know-how to slowing the big BMW as well. Each rotor is fabricated from laser-cut sections of Galfer-proprietary 420 grade stainless steel that is then double-disc, parallel ground for perfect flatness. These friction surfaces are suspended on 7075-T6 aluminum carriers via floating buttons. All of this is designed to eliminate any vibration when the anchors are applied at minor to major brake pressure – and everywhere between.
The wave design provides even brake pad wear, much better than conventional round rotors while at the same time promoting cooler brake operation, which in turn, allows the rider to obtain greater braking efficiency with less effort at the lever. You get smooth, strong performance and good looks to boot.
Carefully designed, engineered, and manufactured in Spain, these brake rotors will not disappoint even the most demanding racers.
If you have any questions or would like to order please contact TJ on 866.931.6644, send a PM or email [email protected] and we’ll get back to you right away!
1 - 2 of 2 Posts
