Ok earlier I had the question about whether a 2nd gen transmission will work in the 1st Gen. Well here is the answer, the gear assemblies and gear shift shaft will work, but the drum, forks and fork shafts won't. If there are issues with the other parts of the transmission, you have to go gen specific. FYI
