1 - 3 of 3 Posts
Hey guys so I'm brand new to this group
I have a 2019 ZX10R ABS I was wondering if anyone else on this group has the same problem as me
So the issue is my Fuse keeps blowing out on me it's a 15A FUSE it's located right under rear seat above the battery I believe its called a fuel pump fuse not to sure all I know is there is a main 30a fuse and I think it's for ecu and I have a 15a fuse right beside it I think it says it's for fuel pump but the 15a fuse keeps blowing on me once I go to pin the Throttle if I ride the bike casual its fine but once I want to go fast it blows witch shuts off the bike and the dash lights up like a Christmas tree any idea what would cause this
Hope you found the problem. A fuse is here to protect the electric components of the bike in case of a faulty component or a short circuit. If the fuel pump fuse keeps blowing on you, then there is likely an issue with the fuel pump or its wiring.
Follow the wire to see if its grounding out. Otherwise something its connected too is drawing too many amps and popping the fuse. Something like a fan or pump going out can pull too many amps while still working as it should.
1 - 3 of 3 Posts
