For some reason my power mode is stuck on that mode. When i first got the bike a year and a half ago i could easily switch it from L, M, F. Now it won't switch. Any suggestions?
I have the same problem but mine is stuck in low power mode I changed the whole lefthand switch cluster just incase it was a bad switch and still stuck I'm at a lossFor some reason my power mode is stuck on that mode. When i first got the bike a year and a half ago i could easily switch it from L, M, F. Now it won't switch. Any suggestions?
Welcome to the forum, did this coincide with any changes to the bike? Did it just happen once and stayed in low power or did it start to be an intermittent issue then become a Sunday blast ruiner? Have you inspected the plugs from controls to harness? And have you inspected harness back to ECU for damage?I have the same problem but mine is stuck in low power mode I changed the whole lefthand switch cluster just incase it was a bad switch and still stuck I'm at a loss
