1 - 11 of 11 Posts
Postwhore with an 04
I know I need a PC3 and custom map to get the most out of a full exhaust system but I was wondering if I can use the full system without the PC3? Will it cause problems? Lean, rich, A/F ratio etc. I wont be running without one for long but if it is going to cause problems I'll wait to install it.
Thanks!
yes it will cause problems! to what degree is the key question??
Is it one of those things I wont know what problems it will cause unless I try it?
i have a full yoshi and not pc3, i know its not smart. but i have ckecked my plugs and they were fine. i know its more of a problem then just it running rich or lean, but havnt noticed anything else.
i run full akrapovics with no pc runs great with no problems but im sure i can get even more performance out of with a pc and will so soon! (on an 06)
I ordered the PC3 and will have it soon but now i need a map that I can use with:
Beet full exhaust
K&N filter
GI Pro
Going to get a custom map after I install an intake cam and thin head gasket but need something that will work until then.
it always better to have a map to go with whatever exhaust system you fit. To maximise the benefit of a full exhaust system has to offer.
A PC3 just makes it slower :sad:
You could seriouly hurt your engine because the full system will cause a lean condition because it breather better.
Leaning to what degree ? I don't know. All I know is that I would not even think of doing it.
1 - 11 of 11 Posts
