1 - 18 of 18 Posts
WELL this just started yesterday i was about to go for a ride BUT the fuel pump would'nt come on:dontknow, this just started out of the blue does anybody have ant idea what the hell could be going on?
I did check the plug
I checked the fuse box
I made sure the battery was 100% chargered up
I put my spare pump on the bike still nothing
:dontknow: HELP:dontknow:
Take off your tank and fuel pump and turn on key with run switch off, get your multi meter ready then flip the run switch to on and test the wires going away from the tank and pump to make sure they have power, if so then you can plug your pump in and put your ear right up to it and listen for noise, or get 2 wires and run from batt to fuel pump and see if it runs the pump. Then you will know if it is the pump or not
ps make sure there is gas in the tank :thumbsup:
the relay box may have crapped out on you....the little black box with the 2 connectors on the top of the ECU.
Tony check the connector on the main wiring harness behind the left side cover. It's taped up with the harness, mine did the same thing. I moved the wiring around and the fuel pump kicked on immediately. It is a 10-12 pin connector and it corrods and burns itself up.
Same problem with my bike, I'll be watching this thread as well. Here's a link to mine that has a lot of suggestions. Good luck and keep me posted if you figure it out.
http://www.zx-10r.net/forum/showthread.php?t=119049
thx i seen yours yesterday i was having something like what your having going on 2 months ago it was my battery plus connector that goes to the relay on the right side:thumbsup:
Discussion Starter #8
thx guys i will check when i get home from work today, its crazy because i was just riding the bike the day before:dontknow:
i did have the fuel circut in the ECU shit the bed too....it was self induced, everythign worked perfect, except the fuel pump priming........replaced the ECU and all went back to normal.
Discussion Starter #10
might sound crazy but i think it was not having my front sprocket cover on, I put my cover back on now my pump is working again crazy, it must be a ground im thinking
Discussion Starter #13
:thumbsup: wasnt the side cover like i thought:thumbsup:
welllllllllll.............what was it then??? (they asked with such inquizzation)
Discussion Starter #15
well it done it again after work i moved the main wiringharness on the left side of the bike it came on, im not 100% sure i think something has a loose connection im still looking:dontknow:
Got my bike fixed at a shop. The problem was a faulty ignition switch. They said it wasn't common at all and it took em a while to narrow it down to that but maybe you could check it out if you haven't fixed it already.
Hi my pump is not priming where should I start. Where does the kickstand switch plug into the harness
1 - 18 of 18 Posts
