Fuel Map Help needed
743 Views 5 Replies 4 Participants Last post by  zx10r_russia
Hi guys,
We don't have a dyno in my are so my fuel map cannot be set precisely, so I want to ask by how many % to enrich the fuel? Now EU stock map, zx10r '10, K&N air filter, fully direstricted M4 exhaust system. Thanks!
1 - 6 of 6 Posts
Do I actually need to change the fuel map? Or the lambda (o2) sensors see that there is more air going in and automatically enriches the fuel mixture?
Do you have a power commander installed. If not perhaps you should consider purchasing one with the auto tune module. With a stock ecu and aftermarket exhaust your running lean.
I you have woolich I can supply you with some maps..
you'll probably want to do an autotune system of some sorts to build the maps and save them to the bike, either via ecu or power commander.
Thank you very much, I think the auto-tune is my solution!
1 - 6 of 6 Posts
