1 - 9 of 9 Posts
Brembo 19x18 Master Cyclinder w/ Folding lever *will work on street bike*$200 shipped
Comes with everything pictures:
19x18 M/C w/ Folding Lever
Brembo Reservoir
Brembo Tubing
Brake Light Switch
Extra Crush Washers
Whats the difference bewteen the 19x18 and the 19x20? Thanks
The first number is the piston diameter. 19mm
The second number is the piston offset. The distance from the lever pivot to the piston. 18mm in this case.
The two most popular Brembo's are the 19x18 and 19x20. Both have a 19mm diameter piston but the offsets are different.
The 18mm requires less lever force but provides less feel.
The 20mm requires more lever force but provides more feel.
Hope that helps.
Discussion Starter · #6 ·
The 18 is usually recommended for track use as the lever action is less. I have used this on both street and track with no issues just improved braking. It is a great mod with SS lines and good high temp fluid.
1 - 9 of 9 Posts
