1 - 7 of 7 Posts
Just curious as to the pros and cons of the 60 vs 70 on the front tire size.
I would imagine the 70 turns easier but is there any drawbacks or benefits otherwise of one over the other?
Gonna be running the michelin power one on a 2g 10R and I am a big guy at 6'2", 280lb so any advice would be appreciated.
The shorter tire turns faster.
I had a vfr1k with 16" wheel, fkn insane handling.17 is more stable
The smaller section will give you faster turn in. But the decreased radius means you are losing some rubber when the tire is leaned over. There is a reason most bike come with the 120/70.
I'm not change wheel size just curious on tire.
I figure the less inertia itself of a 16" vs 17" wheel alone makes a huge difference.
But as far as tire size which would u recommend for aggressive road use for a big guy
Would the less radius of the 60 allow for more braking power in a straight line? I would assume when upright the 60 has more road contact?
Leave it as is. Find something else to change on that gen2, like the brakes, if you aint already
1 - 7 of 7 Posts
