1 - 3 of 3 Posts
:dontknow: Got my 16T front sprocket. Anyone know the torque values for re-installation of the CS nut and rear shaft? Thanx UOO to all!
Countershaft sprocket nut is 92 ft-lbs... Not sure what you mean by "rear shaft" but I'm guessing you're talking about the rear axle nut? :dontknow: If so, it torques to 81 ft-lbs. If you're talking about something besides the rear axle just explain what exactly you're referring to and I can get you the torque spec from the Kawi shop manual. :wink:
Tight is tight...thats the torque.. :wink:
1 - 3 of 3 Posts
