I've got an '04 that's been neglected for the last few years. I finally pulled it out of the garage, swapped the fluids and tires, and took it back to the track. It had been sitting mostly unused since we moved in 2008 with only 3k (mostly track) miles on it.
After my second session, I remembered that I had purchased a 16T front sprocket and never installed it ...
I've got another track day coming up on Sunday and I'd like to make sure I have the tools I need for a swap.
What size is the nut holding on the front sprocket? (Part #92210-1098) I've seen both 27mm and 32mm, but in pictures the nut appears to be 4-sided. What size or 4 or 8 point socket will fit?
It should be OK to reuse the lock washer, right? I've done it in the past on other bikes but I'd like to be sure.
