1 - 4 of 4 Posts
I am trying to remove the front fender of my 06 zx-10r for paint and I am having a hard time removing the black plastic brake hose clamps that hold the brake lines to the front fender. Is there some trick way of squeezing the little clamp to free it from the fender without breaking them?
Grab the ring part from the top side of the fender and push one side in while pulling the other side out. Kind of hard to understand but if you try it as I stated you will see that one side will slide through the hole when the other side is pushed further in.
Thanks for the speedy replies and good info! :thumbsup: Rep on the way.
1 - 4 of 4 Posts
