1 - 15 of 15 Posts
Does anyone know the size of the allen head that fits into the front axle? I think I am going to have to go to Sears to pick one up since the motorcycle shop doesn't have the tool around here.
Good luck bro.
I already went to Sears here in Santa Monica, they don't have it..
Biggest size they have is 10 mm.
Searched online too..
:rolleyes:
That's what I was thinking. Thanks BD. Hopefully I'll have some luck Felix.
Just keep the two pinch bolts on that side of the fork tight until you loosen the axle.
Hell......... I never loosen that side .......ever. :dontknow:
Cheers.:beer:
That is on the first generation........don't know about the others.
La Flama Blanca
You can make a ghetto tool, get some heavy duty bolt with a 14mm head and double nut the threaded part and use a socket wrench on it.
Discussion Starter #8
Thanks for all the info fellas! :thumbsup: I found Sears has some 14mm in SK and a few other brands. Too bad I can't keep to my Craftsman but I guess one tool won't hurt.
Thats not a good idea as the pinch bolts compress the aluminum and although it works it has the real potential to gaul the threads as you loosen the axle.
MIdlife PIMP
Flag down a SNAPON tool truck!!.......28.bucks
Discussion Starter #13
My local Harbor Freight had a whole set of allen-head sockets... from like 10mm up to 20mm for $20.
Discussion Starter #15
Yeah I just moved down and haven't been able to find somewhere like that. However I lucked up at Auto Zone today. They had a 12,14,17mm for 10 bucks. So I snagged that set.
1 - 15 of 15 Posts
