1 - 5 of 5 Posts
Hi,anyone knows the size of the front wheel axle bolt on the left side(shifter side).need to buy the right socket today bc don't want to go back to the store.thank you
You just need to loosen the 27 mm nut (clutch side). You can return the 30 mm as only one side is needed to turn to remove the axle.
You're gonna need a 22mm allen head for that '08, they changed them this year. The wrench and the 3/4 to 1/2 adapter that I needed put me back $43. :headshake just a fyi
What's the 22mm allen head for? I'm assuming the OP has a pre 08 bike. I'm pretty sure I have the tools needed for the 08.
1 - 5 of 5 Posts
