1 - 15 of 15 Posts
yes i searched and no such luck, i hear people talking about airbox mod, exhaust servo removal and butter fly, and 2ndaries removed as well....so can someone point me in this right direction on how to's for these mods...also smog block off plates are they really worth the $100 and where the hell do they go
I purchased smog block off plates for 28 bucks no hp gains just weight shavings and less popping in the exhuast. this is also neccessary when getting your bike tuned, they get installed on top the valve cover...read through this thread: BTW you wont have to worry about the charcoal canister unless your bike is from cali just the air injection selonid.
http://www.zx-10r.net/forum/showthread.php?t=469&highlight=Kleen+removal+AIS
Secondaries are located in the throttle bodies here check this out:
http://www.zx-10r.net/forum/showthread.php?t=51847&highlight=Secondaries+removal
Depends what air box mod your talking about? all four short stacks? im sure someone will chime in about the exhaust. i never delt with it since i have a full exhaust..
Block off
I have some driven block off plates that I'm willing to sell for $25 shipped...They are brand new...Let me know if your interested....
you can do the ram air tube mod. sec flies removed. exhaust valve removal "i just unhook the cables down by the mid pipe and tie the cables up out of your way that way you want get any FI warnings."
Is there pics of the secondary removal someone has?
Licensed Dist of HaterAde
Just take off the airbox and simply take off each butterfly by removing the 2 small screws on each one. be sure and use a screwdriver that fits the screw heads right as they are on there pretty good some times and try not to drop the screws or flies down into the throttle bodies. and while you have the airbox off go ahead and try the airbox mod if you don't want to do the block off plates.you can also remove the servo cables from the mid area of the headers and zip tie them out of the way OR remove the completely, just leave the box plugged in unless you try Hellsrazor's servo eliminator mod (last link) i threw a couple more free mods on here as well. hope any of this helps bud!:thumbsup:
http://www.zx-10r.net/forum/showthread.php?t=51847&highlight=secondary+butterfly
http://www.zx-10r.net/forum/showthread.php?t=79926
http://www.zx-10r.net/forum/showthread.php?t=17771
http://www.zx-10r.net/forum/showthread.php?p=1648725&posted=1#post1648725
I've got one more question. I work for Graves Racing as the Parts/ Sales guy for racing product. I got a PC5 made for my bike and while installing it i was trying to remove my airbox and I couln't figure out how to squeeze that thing out. Could you maybe shine some light on that for me?
turn it about 45 degrees counter clockwise and slip it out...some guys will remove the ram air tubes and some leave them in...the trick is to have the airbox sideways inside the frame or you'll never get it out (thank you kawi engineers!!!!)
Ah HA. I totally can see it my head. Awesome thanks again man
:thumbsup:....yeh once you get it out a couple times then it's not a problem but the first couple times i took mine out i remember thinking WTF is going on?!!!!:badteeth::lol:
the screws on the flies need to be heated.I just heated my screwdriver with a torch then let the screw get hot or you will strip the heads of the screws,there is loctite on them.On the block off you can just run a hose between the two
1 - 15 of 15 Posts
