1 - 3 of 3 Posts
Found why the bike keeps blowing the ECU fuse and will not start. The harness conncecter that goes to the back of the dash is shorted some how. The pin that is labeled ground has 12.65 volts or battery voltage to it. And the ground pin has no continuity between the pin and the battery negitive. how could this of happened. and common areas where some wires could of been crossed during re-assembly
1 - 3 of 3 Posts
